shock boots?
p_2_biking
PostPosted: Thu Mar 02, 2006 8:22 pm    Post subject: shock boots? Reply with quote
hey guys, i was just woundering if there is a trick to installing shock boots so sand doesnt get stuck in the boot and scratch at the shock arm, or do i just zip tie both ends...anything? i will be installing them on saturday so i need to know how you would install your boots, im thinkin just zip tie both ends
PostPosted: Fri Mar 03, 2006 5:19 am    Post subject: Reply with quote
The trick is to not install them. All they do is trap dirt, sand, and moisture inside the boot and speed up rusting and damage to the shock.
PostPosted: Fri Mar 03, 2006 8:30 am    Post subject: Reply with quote
But they look so cool. rofl
I agree...I learned it the hard way.
p_2_biking
PostPosted: Fri Mar 03, 2006 5:40 pm    Post subject: Reply with quote
so the 4 shock boots i got just dont put them in even though ill be driving in the desert and shit....well...thats easy i guess...comfirm this....*dont install shock boots at all*....ok thanks
p_2_biking
PostPosted: Fri Mar 03, 2006 5:44 pm    Post subject: Reply with quote
oh yeah also.....wat torque should i torque my wheels back on too..and also does anyone have any tricks for taking off striped lugs because sum idiot striped one of the lugs on the front tire...alright thanks
KnightFire
PostPosted: Sat Mar 04, 2006 8:42 am    Post subject: Reply with quote
Yep, but your going to have to sacrifice a socket to do it, get a socket that is just BARELY too small to fit the lug nut, BEAT it on with a hammer...now use your breaker bar and socket wrench to remove it, hopefully its just the lug nut and the wheel stud thats stripped.
KnightFire
2002 TJ Wrangler X
Patriot Blue 4.0L
Check Website for Mods/Photos
Amsoil Dealer
PostPosted: Sat Mar 04, 2006 9:12 am    Post subject: Reply with quote
i used a big ass hammer beat the stud out, carefully though
then put the new one in and used a lug nut and the impact gun to pull it through
PostPosted: Sat Mar 04, 2006 4:39 pm    Post subject: Reply with quote
The lugnuts should be torqued around 75 ft/lbs in an alternating pattern. As far as removing a stripped lug, I've used a socket, a c-clamp and an impact gun with a lot of success....but unless you remove the axle shaft, there's not enough room to do it. I know autozone sells a press for around $30 that will do the job...hell, they prolly rent it out.
Good Luck.
