extend ball joint life
carlomencucci
PostPosted: Sat Mar 04, 2006 6:47 pm    Post subject: extend ball joint life Reply with quote
To extend the life of the original ball joints should this be done? Take a spray can of white lithium grease and using the spray straw up under the lip of the dust boots give all four ball joints a shot of grease at each tire rotation. Would this void my warranty? I was planning on doing this with my new 06 liberty when the time comes.
The replacement lower ball joints are the Moog heavy duty greaseable K-3199. What is the Moog replacement number for the upper greaseable ball joints with the upper control arms?
Thank you
swtwomyn
PostPosted: Fri Apr 21, 2006 9:38 am    Post subject: Hi there! Reply with quote
Try your question on www.lostkjs.com forum.
Good luck!
Tracy
