Tire Question
TJTank
PostPosted: Sat Feb 25, 2006 1:27 pm    Post subject: Tire Question Reply with quote
I currently own a 98 TJ sport with a 1" body lift. I am planning to eventually add a 4" suspension lift with some 33x12.50 tires but in the mean time I would like to run the widest 31" that will fit without rubbing, I plan to run 15x10 rims, how much backspacing should I use, so that I donít need to buy new rims when I switch to 33's?
Thanks for any help you can give me.
98 TJ Sport
kizer
The Link Meister
The Link Meister
PostPosted: Sat Feb 25, 2006 5:32 pm    Post subject: Reply with quote
Not sure if it helps much, but Im currently running 33x12.50s with 4.25-inchs of backspacing on a 8-inch rim and at full turn I would rub my tire on the control arm. I added a washer to bothsides on my steering stops and now I dont rub on the control arms.
Question why do you want to run 15x10 rims? Nearly everybody I wheel with runs 15x8's and they dont have any problems with the tire unseating off the rim. I think if you go with a 10-inch rim and if you air down you could loose a bead.
Links4Jeeps.com
1600+ Write-ups, and more
My Writeups | My Heap
misfit8
PostPosted: Mon Mar 06, 2006 10:25 am    Post subject: Reply with quote
3 3/4
99 TJ
"Lightly Modified"
Graig
japago4
PostPosted: Thu Mar 16, 2006 6:46 am    Post subject: Reply with quote
misfit8 wrote:
3 3/4
I agree...can't go wrong with 3.75" backspacing.
Jim
2004 Rubicon | 6" Full Traction Long Arm | 17" Walker Evans Beadlocks | 35x12.50 Nitto Mud Grapplers | ORO U-turn Steering | Homemade Bumpers and Spare Carrier | 5:13 Gears
