turn singals and brake light problem
justin
PostPosted: Sat Mar 18, 2006 8:17 am    Post subject: turn singals and brake light problem Reply with quote
i just got a 94 grand cherokee and had it for almost a month now and the blinks started to not work and the brake lights the only way they will work if i turn on the high beams and hold them on then the turn singals work and brake lights........plz help
BeachCrawler
PostPosted: Sat Mar 18, 2006 9:21 am    Post subject: Reply with quote
Did you check the turn signal switch? It can cause a problem with the signals and the brake lights.
'94 ZJ, BB, 31x10.5
'98 ZJ (Canadian Specs) Upcountry springs, 2-1/4" BB, RE rear TB Bracket, OME springs
justin
PostPosted: Sat Mar 18, 2006 9:38 pm    Post subject: Reply with quote
and now my power doors wont work and all the fuses are fine...... Evil or Very Mad Crying or Very sad
BeachCrawler
PostPosted: Sun Mar 19, 2006 12:27 pm    Post subject: Reply with quote
It is beginning to sound like bad ground somewhere in your wiring. Unless you have the skills, you may need to have an electrical expert track down the problem.
'94 ZJ, BB, 31x10.5
