Fuel pump pressure
sand zj
PostPosted: Tue Mar 21, 2006 9:03 am    Post subject: Fuel pump pressure Reply with quote
I see the post with the MSD pump. Is this sufficient for my 96 w/ 5.2? The factory system has no return line right? So does this pump have a built in pressure switch or regulator? I have a fuel cell that I would like to put in but I would like to maintain the factory injection system at least untill next winter when I have the time to put a stand alone system in with twin turbos Twisted Evil
Any tech help would be appreciated.
Dan Vannette
If you never get stuck...keep trying!
PostPosted: Tue Mar 21, 2006 5:16 pm    Post subject: Reply with quote
Pre 96 has a return line at the regulator on the fuel rail..
Post 96 its in the tank.. Part of the fuel pump. If you do the Swampy Bypass you will have to buy an aftermarket fuel pressure reg and loop the return to a T thats before the fuel pump..
I did something simular by swapping on 98 fuel rails and a fuel pressure regulator ..(Hooked to stock return line..)
