Strange rattle
nolajeep
PostPosted: Thu Mar 23, 2006 1:17 pm    Post subject: Strange rattle Reply with quote
Does anyone else have this problem? I have a 1990 4.2 auto. I just recently started hearing a loud rattle during acceleration. It does'nt do it all of the time. Mostly after i hit the gas from cruising, and sometimes from a dead start. It seems to only do it after the engine warms up, and does not do it at all in neutral or park. sounds like it is coming from the transfer case area or possibly cat. converter. Does not appear to be in the engine area. Any help would be appreciated. Thanks!
tonloco
PostPosted: Fri Mar 24, 2006 9:24 am    Post subject: Reply with quote
sounds like mine when the cat. con. went out mine did the same thing
PostPosted: Fri Mar 24, 2006 1:24 pm    Post subject: Reply with quote
Best way I could describe mine was it sounded like shaking gravel in a coke can.
nolajeep
PostPosted: Fri Mar 24, 2006 1:25 pm    Post subject: Reply with quote
thanks! appreciate the info.
