How wide of tire can i fit on stock wheels
S_Munk13
PostPosted: Fri Mar 24, 2006 6:52 pm    Post subject: How wide of tire can i fit on stock wheels Reply with quote
Another noob. Been viewing posts for quite a while and decided that maybe i should just sign up . So my question is I have a 5.9 limited that still has original rubber from the factory on it. Its time for something new. I like the look of the Durango with the wide tires, but also like the look of the 5.9 wheels. Whats the widest tire i can fit underneath with out modifying or any rubbing?
Scott
5.9 Limited
PostPosted: Fri Mar 24, 2006 7:52 pm    Post subject: Reply with quote
30x9.50 not positive about metric sizes
S_Munk13
PostPosted: Fri Mar 24, 2006 9:25 pm    Post subject: Reply with quote
Thanks. The conversion showed 255/70 16. I was looking at running 245/70 16 so i should be ok
Scott
5.9 Limited
PostPosted: Sun Mar 26, 2006 8:15 pm    Post subject: Reply with quote
I ran 31X10.5 on my stock rims... No problem..
S_Munk13
PostPosted: Sun Mar 26, 2006 9:00 pm    Post subject: Reply with quote
Thanks for the info, but i guess the question aint as much the rims as it is the fenders. I am not raising it at all and I dont want to cut away the fender to make room. Will the rub? If sohow much? Just in reverse or lock to lock?
Scott
5.9 Limited
