Dana 44 & Dana 30 Technical Information Needed.
BunGhoLeo
PostPosted: Fri Mar 31, 2006 12:25 pm    Post subject: Dana 44 & Dana 30 Technical Information Needed. Reply with quote
I need some information from someone who has rebuilt the dana 44 and 30's, perferably ones from a 1997+ wrangler.
I need to know if the oil slinger and baffle are used in the dana 44. I started with a bare housing so i have no referance. It was mentioned before that the starting pinion shim thickness is 0.042", and that gives almost a perfect pattern without the slinger. The slinger is 0.030" thick, so it changes the shim pack to 0.012".
My dana 30 in my TJ does have the oil slinger, but not the baffle, so i have to asume that the slinger will go back in, and not the baffle.
If anyone has the technical manuals for these axles the information would be most helpful.
