Dana 30 confusion
srb96bravo
PostPosted: Wed Apr 05, 2006 6:13 am    Post subject: Dana 30 confusion Reply with quote
I have read and looked a lot of write ups for replacing hub assemblies. This is on a 97 XJ, so dana 30, non vac. It hasnt really come up in the write ups and now a friedn has me confused. After I pull off the spindle/hub assemly, will the axle shaft just slide out? Write ups just say pull it out, but he thinks i need to crack the diff to take off c clips first. If so none of the write ups I found mentioned that. This may be common sense to some, but I'm not there yet.
jppilot61
PostPosted: Wed Apr 05, 2006 7:10 am    Post subject: Reply with quote
I was JUST into my 92 XJ Front Axle to install Lock Right Locker.
I had to pull axles to remove differential carrier because Ring Gear was too thick to remove Pinion Shaft.
There are NO C Clips on my Dana 30.
I removed Bearing caps to remove Differential but don't think they have to be removed to remove axles.
Hope this helps!
1992 XJ Laredo
RE6130 4.5" XJ Super-Flex Kit
srb96bravo
PostPosted: Wed Apr 05, 2006 10:24 am    Post subject: Reply with quote
thanks, hopefully there aren't any c clips I need to remove to just slide the axle shaft out.
scorpio_vette
PostPosted: Wed Apr 05, 2006 1:02 pm    Post subject: Reply with quote
you DO NOT have to open the diff. there are not c-clips.
once you have removed the brakes and the hub, you just pull the axle straight out.
be carefull when putting the axle back in. use a vacuum to suck the dirt out of the axle tube first, or if you don't have one, then try to insert the axle in without letting the splined end slide on the bottom of the tube. otherwise you will push alot of dirt into the diff.
________
find headshop
srb96bravo
PostPosted: Wed Apr 05, 2006 3:11 pm    Post subject: Reply with quote
good to know. Well I'll have fun with that soon, let you know how it turns out, also if it cures my vibration.
