Red maintenance light stays on?
Shimma
PostPosted: Thu Mar 23, 2006 9:14 pm    Post subject: Red maintenance light stays on? Reply with quote
I've just bought a Cherokee Sport 1997,sight unseen in the flesh,(is 800 kays away!!,,sounds and looks in a nice well kept knick,(only 56,000 on the clock) going by the web photos,of it. This truck arrives down here,on a transporter,Tues coming,but was just told today,and after a service prior to this delivery,that this red light stays on now,all the time? Not sure,as I ve never sat in one!!help,what area should I be 1st looking at,please?..cheers..Jim..New Zealand...
PostPosted: Sun Mar 26, 2006 3:25 pm    Post subject: Reply with quote
Sounds like a check engine light. Any maintenance shop can hook up an OBD computer and tell you what the code is, or you can do a certain key sequence in your ignition to tell you what code it is (should be searchable in this forum). If the code is bogus though the shop guy can clear it out for you.
Shimma
PostPosted: Sun Mar 26, 2006 6:47 pm    Post subject: Reply with quote
Thanks for that,Drake69, cheers ...Jim
PostPosted: Sun Mar 26, 2006 10:28 pm    Post subject: Reply with quote
The check engine light would be orange...not red. The most likely candidate is probably the Check Gauges light.
Shimma
PostPosted: Tue Apr 04, 2006 2:26 am    Post subject: Reply with quote
My mistake,it's the red top left cnr light 'maint required'. I did the key on-off-on-off-on thing,and it shows up as codes 12 and 44,which both relate to the battery,12 means disconnection within the last 50 starts,whatever that means,and 44 is the battery temp sensor. Where is this temp sensor,situated,I guess it must be close to the battery?Is it one of the wires connected to a terminal?. Im not sure what I'm looking for!! Very Happy cheers...Jim
jppilot61
PostPosted: Tue Apr 04, 2006 1:05 pm    Post subject: Reply with quote
From my (1992) Cherokee FSM:
"Maint Reqd" - Used to alert the owner when oxygen sensor-PCV valve replacement and other scheduled emission maintenance is required.
Activated when vehicle mileage reaches the scheduled maintenance interval of approximately 133,000 kilomenters (82,500 miles).
Can be reset with the use of DRB II after appropriate sensor/valve replacement and maintenance is accomplished.
Be aware this is from 1992 FSM but probably still applicable. Hope this helps!
1992 XJ Laredo
RE6130 4.5" XJ Super-Flex Kit
Shimma
PostPosted: Wed Apr 05, 2006 6:15 pm    Post subject: Reply with quote
thanks,but as I said above,the keycheck flash code says it's the battery temp sensor,so I guess thats what I should be looking at....cheers anyway..Jim
jppilot61
PostPosted: Thu Apr 06, 2006 2:38 am    Post subject: Reply with quote
Maint Reqd light is not to be confused with Check Engine Light (CEL).
You should have both (even tho CEL may not be on).
The code for battery temp sensor, most probably is not reason for MAINT REQD light being on. You can fix it and the light will not estinguish I am betting.
Just my best guess . . .
1992 XJ Laredo
