OK, advice needed...
srb96bravo
PostPosted: Tue Apr 11, 2006 5:41 am    Post subject: Reply with quote
what about the cable actuator? it would be useless after that?
badger
PostPosted: Tue Apr 11, 2006 6:55 am    Post subject: Reply with quote
yep it wouldn't have a purpose.what front axle is it LP or HP?is out of a XJ?
[quote=scorpio_vette]
pull his axles shafts out. replace the axle seals with seals for 1piece axles shafts, pull off the vacuum motor. plug of the hole in the cover plate and bolt it back up. now you have a non-vacuum disconnect axle. i've done that to a couple axles already.[/quote]
the problem with this is he would be buying an axle with alloys that he wouldn't be able to use.
One Built XJ
