Seat slide question I should have asked before!
omega1300
PostPosted: Fri Apr 21, 2006 4:55 pm    Post subject: Seat slide question I should have asked before! Reply with quote
I'm wondering if any of you guys know if there are replacement front seat slides (or a way to move the OEM ones) so that you can slide the drivers seat back further? I'm 6'3" and it would be really nice to get a little more leg room when im driving.
Also, I've been reading a bunch of posts on lifting, and it seems if you are going for a smaller lift (3"-3.5") you don't have to change nearly as many ofther things along with the lift, is that right? How complete are teh Rubicon Express Lift, or what would you guys recomend? I'm just going for a bit of a lift and the ability to run some larger tires for some mild off roading for now.
THanks for all the help, you guys are awsome
Kingfish
PostPosted: Tue May 02, 2006 1:32 pm    Post subject: Re: Seat slide question I should have asked before! Reply with quote
What I did on my '90 was to just move the whole seat back 3 inches. I unbolted, drilled new holes, added some steel plate to the underside and rebolted with grade 8 bolts.
