Max Life easy fix
97XJ Jeeper
PostPosted: Sun Apr 23, 2006 1:59 pm    Post subject: Max Life easy fix Reply with quote
I have used Valvoline Max Life 10w30 the last 2 oil changes and it has stopped all the leaks i had. it does not leak a drop. just letting you guys know in case you would like to try it before you go tearing into your motor to fix leaks. now if they only made it for diffs. rofl
JUST PUT IT IN 4X4 AND GO FOR IT!!!
Magnaflow high flow cat
FLOWMASTER SUPER 40
2 1/2" pipe cat back
Videos my XJ
http://youtube.com/profile?user=JeepXJJeeper
pipxj
PostPosted: Mon Apr 24, 2006 8:48 pm    Post subject: Same here Reply with quote
Have been running the stuff for two years now. Haven't had my idiot light come on and the only things I've done is the standard tune up with new sensors and regular oil changes.
And the four banger just turned over 190k yesterday so something must be doing it.
