jeep cuttung out!!!
95JeepShot
PostPosted: Wed Apr 26, 2006 2:02 pm    Post subject: jeep cuttung out!!! Reply with quote
i have a 95 jgcl 4.0.it has been stalling out on me on the highway,not starting after a short peroid of time wnen off,im at wits end.replaced fuel pump[used low mi],cam sencer.plugs wires.ihave codes i pulled that sayPROBLEM WITHDIST.SYNSCRO.CIRCUIT. what does that telling me .please help its getting dangerous to drive.thanks
XTOZJ
PostPosted: Wed Apr 26, 2006 4:59 pm    Post subject: Reply with quote
I had a Chevy 350 that would do same thing, turned out to be the pickup coil inside distributer. at first it would just die and restart,then it stayed out longer periods and finally wouldn't start at all. On mine dist had to be pulled and disassembled to replace coil. Not sure on Jeep. But it solved the problem. From the code it sounds like it may be the problem.
It's a JEEP thing.... you wouldn't understand!
If it ain't a JEEP, its a wannabe!
Happy trails to you!
Whats in your holster?
95JeepShot
PostPosted: Wed Apr 26, 2006 5:38 pm    Post subject: Reply with quote
i have been told its the fuel pump but i cant believe it would happen totwo pumps.so iam leaning toward dist. replacement.
raytech
PostPosted: Wed Apr 26, 2006 9:00 pm    Post subject: Reply with quote
do you get a code for the crank position sensor?
My 94 would die while driving, and sometimes restart on its own, while moving. Sometimes it would not start after being shutoff for about 20 minutes or so.
It was the crank position sensor.
Changed the senor, and no more problem.
any advice is welcome, novice to expert.
95JeepShot
PostPosted: Thu Apr 27, 2006 3:17 am    Post subject: Reply with quote
i did not get a crank code,but did you get one on yours before you installed your crank sensor.i read on another thread that may be the problem.
PostPosted: Thu Apr 27, 2006 5:21 pm    Post subject: Reply with quote
Not sure the CPS throws a code.. But its not that expensive.. I would pull it out and look at it. .They normally look bad when you look at them..
All the ones I have seen go bad looked melted..
raytech
PostPosted: Thu Apr 27, 2006 9:07 pm    Post subject: Reply with quote
code 11
Bishops Finger
PostPosted: Fri May 26, 2006 1:06 pm    Post subject: Reply with quote
Could be the O2 sensor...
