Head lamp wiring situatiom Adopted Cherokee
plym_46
PostPosted: Sat Apr 29, 2006 6:50 pm    Post subject: Head lamp wiring situatiom Adopted Cherokee Reply with quote
The 99 I picked up from a repo auction had some front end damage. fender, bumper and header panel basically. I sourced a header panel complete with lights and wiring harness. I plugged the new harness into the original wiring junction box near the air filter box (undamaged) and got marker lamps, running and signal lamps, and low beam on the pass side, no low beam on drivers side, nor highbeam on either. Any hints on tracing these circuits, I found some blown fuses, which I will be doing tomorrow.
Grounds for the side markers were not good, I jumped to chassis bolts with jumper wires and got bright lights.
If yer running a flathead, how come yer plugs are slanted
Kingfish
PostPosted: Tue May 02, 2006 12:29 pm    Post subject: Reply with quote
Relays may have been smushed or otherwise damaged. Someone with an FSM may be able to tell which ones.
