Tranny Problem...
SKOT
PostPosted: Fri May 05, 2006 3:51 pm    Post subject: Tranny Problem... Reply with quote
Whatís up guys? Iím new to this forum, but HOLY CRAP was I excited to find it. I just wanted to bounce something off you guys before I go out and spend a bunch of money needlessly.
Last week I went to take off from a red light and the tranny wouldnít shift into gear. It just revved high and then eventually slowly started moving me forward. I went straight home changed the fluid, filter, tightened the bands and added some Lucas. It seems like itís been running fine since then.
What I noticed though is that before I changed it my fluid was really fullÖover full. Iíve also been having a problem with my radiator getting low although Iím not aware of any leaks. Iíve heard that since the trans cooler is integrated into the radiator itís possible for coolant to leak into the tranny fluid. Anyone ever have a problem with this? Is it true?
I figure itís better to be safe than sorry. Iím thinking about replacing the radiator with a 3-row one from Radiator Express. They have it for $140. So what do you guys think? Does it sound like Iím on the right track here? Any help would be appreciated.
1995 Grand Cherokee
3" Explorer Pro Comp Lift
31" BFG A/T
greedy7
PostPosted: Sat May 06, 2006 10:49 am    Post subject: Reply with quote
sounds like what just happened to my zj. red ligh turns green. hit the gas, nothin, just reved real high and i stared movin at about a miloe an hour. had to have the thing towed to the house. fluids are fine. guess i just need a new tranny. new radiator sounds like a good fix.
mski22
PostPosted: Thu May 11, 2006 5:44 am    Post subject: Reply with quote
My radiator fluid has been getting low too. I finally realized that my heater core is bad and that it is leaking into my heater vents. My windshield fogs up really bad and when i turn on the heater is smells like antifreeze.
I noticed that my jeep hesitates at take off but only if i am in a hurry. It only happens when I start the engine and put it into gear while the idle is still high. I usually let the engine come down from the intial start and let the engine warm up a little.
SKOT
PostPosted: Sun May 28, 2006 8:44 pm    Post subject: Reply with quote
I got the radiator swapped out this weekend. When I got the old one out I could see there was corrosion around the area where the trans cooler lines go into it, so I'm thinking I was on the right track. Only time will tell for sure I guess.
I upgraded to the 3-row radiator and it made a big difference in the operating temp. It runs a lot cooler now. I'm very excited about that seeing as how I live in the middle of the desert.
1995 Grand Cherokee
31" BFG A/T
PostPosted: Mon May 29, 2006 6:02 pm    Post subject: Reply with quote
Sweet.. Where did you get your radiator???
I have an all metal radiator but its only 2 core.. I would like to swap in a 3 core..
SKOT
PostPosted: Tue May 30, 2006 10:55 am    Post subject: Reply with quote
I got it from Radiator Express. I actually ordered it through their eBay store because it was cheaper that way than just going through them directly...go figure.
http://stores.ebay.com/Radiator-Express
1995 Grand Cherokee
31" BFG A/T
PostPosted: Tue May 30, 2006 5:53 pm    Post subject: Reply with quote
Well crap.. Thats where I ordered mine from about 2 or 3 years ago... They only offered 2 core then..
I guess I will have to upgrade.. Mr. Green
Although since I am running an external tranny cooler Its not nearly as hot...
