Noise from Tire or Rear End?
PostPosted: Wed May 17, 2006 6:47 pm    Post subject: Noise from Tire or Rear End? Reply with quote
Hi All from Down Under - im looking for feedback on a noise coming from the rear of my 96 XJ (stock) sounds just like a flat spot on a tire and varies in frequency with road speed but is only heard on acceleration and can vary with road surface changes...goes away immediately on cruise or decel...first noticed it after a day of playing in the sand where capstone was present with tire pressures down to around 16psi...there are no noticeable signs of a separated/damaged tire belt...if it were a tire issue i would think it would be there all the time...ive also had the rear diff serviced (twice now) and nobody said anything about any issues there but im thinking this could also be a ring and pinion problem (and yes, additive was used in the services)...the wrig has 118,000 miles on it and has been gone over with a fine tooth comb - the u joints especially have been examined several times and all looked good...the only other thing i can think it might be is the leading edges of the brake shoes (rough and worn down to 30%) might be rubbing the drum but the noise doesnt go away when i pull the ebrake handle...thanks in advance for anyones help - Roger
