Tcase Swap : Different Output Front Yoke
egc519mzl
PostPosted: Fri Jun 02, 2006 9:40 am    Post subject: Tcase Swap : Different Output Front Yoke Reply with quote
Hi,
I swapped the input shaft from 249 to 231 and reassembled the tcase. I already noticed before that the front output yoke of the two tcases have different shapes. When I tried to swap it, the two yokes have different sizes in holes. 249 has I think 33 shaft spline count and the 231 have 27. And I cannot use the yoke from 231 because it is wider. I think, it will rub or bump with the double cardan joint.
These are my thoughts:
1) I will look for a slimmer yoke with the same spline count.
2) I will replace the double cardan joint. No idea yet how to.
3) Temporary. Will install the tcase and remove the front driveshaft just to see the truck run. Very Happy .
Any suggestion? Thanks...
94 ZJ Laredo Hunter Green
Bought with broken tcase and leaking radiator. Undrivable condition. My first auto project.
PostPosted: Sat Jun 03, 2006 3:57 pm    Post subject: Reply with quote
Maybe you could use a shaft from an XJ ??? or something..
Post pics of your new front output and your old shaft...
egc519mzl
PostPosted: Sat Jun 03, 2006 7:28 pm    Post subject: Reply with quote
Having some problem with my host server doing a direct link... Try this... http://www33.brinkster.com/edjelcen/jeep/FrontYoke.htm
PostPosted: Sun Jun 04, 2006 9:30 am    Post subject: Reply with quote
What did you get the case out of??
Maybe you can get the shaft to go with it..
Is the jolk for the same size joint??
egc519mzl
PostPosted: Sun Jun 04, 2006 12:33 pm    Post subject: Reply with quote
It is from a 93 XJ. I measured the diameter of the yoke ears and both have the same diameter.
I will just scour for a front DS. THanks...
