95 Jeep Grand Larado bucking and sputtering intermitently
bobsspike
PostPosted: Fri Jun 02, 2006 11:38 am    Post subject: 95 Jeep Grand Larado bucking and sputtering intermitently Reply with quote
95 Jeep Grand larado 5.2 V8 replaced:fuel filter,plugs, and repaired vac leaks. I drive about 280 miles in one trip and I lose all acceleration and I start bucking and sputtering until I pull over and let the car cool. at this time: I have had the air conditioning on for the entire trip. The engine light does not come on. The engine is at normal operation temp. I have 1/4 of gas left in the tank. all runs fine untill the long trip. this has happend in very hot weather from OK to TX. 95 degrees and high humidity. any ideas would be greatly appreciated. This has happend going to TX and coming back. Maybe its because I am in the longhorn state. Yeah thats got to be it. Go Sooners
bobsspike
_______________________________________
The answer is 42! The question is another matter all together.
PostPosted: Sat Jun 03, 2006 3:48 pm    Post subject: Reply with quote
Crap... Thats a new one.. But check all your temp sensors and your air charge temp sensor. (Thats on the front of the passenger side at the top..
raytech
PostPosted: Sat Jun 03, 2006 8:04 pm    Post subject: Reply with quote
Sounds like your motor might be getting tired. It is possible that you bearings are tightening up as the motor heats
any advice is welcome, novice to expert.
bobsspike
PostPosted: Fri Jun 09, 2006 6:29 am    Post subject: OK I think I have the answer from a friend. but! Reply with quote
Well I can not check this without the cash for a new pump. He said that it is the pump motor over heating in the tank and causing it to seize in the pump itself. It would be good if it would just die so you will know that is it. but without a normal break fix problem it is so intermitent that he cant pin point it. I have noticed that if I fill the tank up right when it happens that it seems fine for a while. I think I have a over heating pump. how strange, I could have sworn it was because I was in the long horn state. A OU jeep cant take being out of its native state of OK. Thanks for the help
bobsspike
redzjon31's
PostPosted: Tue Jul 18, 2006 11:50 am    Post subject: Reply with quote
Check the O2 sensor mine was bucking and sputtering also and i replaced the O2 sensor and it hasnt done it since and sometimes the check engine light would come on it was very weird
