Suspension Clunk
Dan
PostPosted: Wed Jun 07, 2006 11:18 am    Post subject: Suspension Clunk Reply with quote
I replaced my right front hub, U- Joints on both sides and my steering dampener on my 98 JGC w/ 4.0L 6cyl last weekend. Now when I go in reverse the first turn I make makes a clunk sound… it only happens once. Then it when I put it in drive and move forward, the first turn I make makes the same sound and I stress it only happens on the first turn in either direction. After the initial clunks the jeep runs very smooth. To get my steering dampener out I had to pound on it w/ a hammer where it connects to the drang link, could I have bent something or could this be a tie rod problem (I plan on replacing them soon anyway).
Any/All help is appreciated.
Thanks
Clean your engine. It will thank you.
Dan
PostPosted: Fri Jun 16, 2006 10:40 am    Post subject: Reply with quote
No One?
RockOn
PostPosted: Fri Jun 16, 2006 12:25 pm    Post subject: Reply with quote
is your jeep full time 4 wheel drive?
kinda sounds like you got something binding....going from reverse to forward & when turning??? seems like binding to me....maybe the front driveshaft is worn? you could take it out & try driving without it & see if it still does it.
it may help narrow down where it is coming from.
89 or 90? XJ
PostPosted: Fri Jun 16, 2006 3:37 pm    Post subject: Reply with quote
Put the front axle on Jack stands and wiggle every component on the front axle.. Control arms .. Track bar ... Steering linkages.. U joints.. Whatever ...
You will probobly find what is loose then..
PostPosted: Fri Jun 16, 2006 5:54 pm    Post subject: Reply with quote
i seem to have the similar problem except mine is more than one clunk....i replaced the hub assembly noise goes away, few weeks later the noise returns, replace the hub assembly noise goes away, comes back again...i have yet to figure it out
Wilder
PostPosted: Sat Jun 17, 2006 9:31 pm    Post subject: Reply with quote
My 94 Grand cherokee just started doing that since the last time i went out 4x4ing. I've tore the front end apart and yet to have located the source. Mine is more located to the passenger front. Only clunks once when changeing direction..
It is the all wheel drive model btw.
PostPosted: Sun Jun 18, 2006 5:22 pm    Post subject: Reply with quote
mine is on the passenger side as well, and i have the 231 case so im not 4 wheel full time
i pulled the axle, replaced the ujoints, wheel bearings and ball joints
still after a few weeks the noise comes back
Dan
PostPosted: Mon Jun 19, 2006 10:33 am    Post subject: Reply with quote
I don't have the all time 4wd. but a mechanic friend of mine said to check the drive shaft U-Joints so I'll post back when I get to that. In the next day or so
