One loud pop tight turn
demigod
PostPosted: Mon Jun 26, 2006 4:35 pm    Post subject: One loud pop tight turn Reply with quote
I blew my rear U-joint, replaced joint and now when going in low speeds and turning(such as in a parking lot) I get one loud pop. What is this?
keihne
PostPosted: Mon Aug 21, 2006 11:20 pm    Post subject: Reply with quote
check the lower steering shaft where it goes into the gear box. there is a pin in it with rubber that holds it. bad design. the pin knocks back and forth.
JV03
PostPosted: Fri Oct 27, 2006 10:58 am    Post subject: Reply with quote
I just made a post that sounds to be a similar problem...Do you have a picture or more detailed explanation on this? It sounds like something I need to look into. Thanks
JV
