1999 cherokee sport utility
longfellow
PostPosted: Sat Jul 08, 2006 5:50 am    Post subject: 1999 cherokee sport utility Reply with quote
ok need to know what basic service I should do on this vehicle because of unknown service by past owner? Vehicle has 90k on it.
such as serviceing Trans, Differential . What type oil do you use in these motors or recommended best? Any general listing to check so I feel secure on highway with it. change engine cooland ect..???
Thanks , Longfellow
PostPosted: Sat Jul 08, 2006 9:24 am    Post subject: Reply with quote
The FSM recommends 5W-30 or 10W-30. I run 5W-30 in the winter and 10W-40 in the summer. I also run a Mobil M1-301 (or equvilent) oil filter. It's a little bigger than the stock filter and holds and extra 1/2 quart of oil.
If it's an AW4 (auto) tranny, it takes DextronIII/Mercron. Change the filter there too.
In the diffs, I run a synthetic 75W-140, but I think the FSM calls for 80W-90.
I would definatley flush and change the coolant, hoses and thermostat. Also tune it up - plugs, wires, cap, rotor, O2 sensors and air filter.
Clean the throttle body as well. While you have it off, check and clean the IAC.
Give the brakes a once over and replace pads/shoes/rotors/drums as necessary.
Grease all the zerks too...
