WJ Bad Vibrations.
LambAtLaw
PostPosted: Wed Jul 19, 2006 10:52 am    Post subject: WJ Bad Vibrations. Reply with quote
Hereís a puzzler worthy of Click and Clack. At about 49,000 miles, my í01 WJ Limited developed an intermittent front-end vibration. It wasnít bad in the beginning but a month later by 50,000 miles, it had gotten more frequent and enough worse that I had the Jeep dealer check it out. They told me my OEM Goodyear Wrangler SRAs, 235/65 R17, were causing the problem and needed replaced even though they probably had another 10,000 miles of wear left.
So I bought four Toyo Proxes S/Ts, 255/60 R17, and they were great tires in all respects--for about five months. Then the vibration started again and quickly became much worse than before. Applying the brakes at 50 MPH and above made the vibration much, much worse--like the worst warped brake rotors you ever saw. At 70-75 MPH, it was so bad--and so noisy--once that I thought I had a flat tire or something wrong with the steering and actually pulled off the freeway to check. Like before, the vibration didnít happen all the time, and I couldnít--and still canít--find common cause. It appears to happen completely randomly.
The Jeep dealer checked it out and told me that three of my four new Toyos were out of round so I went back to the Toyo dealer. He said he was familiar with the problem because he had the same thing happen with the Proxes S/Ts on his truck. He said that this was a problem with the Proxes S/Ts caused by bad rubber and that Toyo was working to correct the problem. He did some kind of a super road-something-or-other balance and sent me on my way.
Soon it happened, and the tire dealer began giving me the run-around. So I emailed Toyo about the problem, and I got four new Proxes S/Ts at no charge a couple of weeks ago. Now Iíve got the same problem again.
I donít know whether any of this is relevant, but just in case, Iíve got the 4.7L V8, QuadraDrive, 17Ē Rogue chrome wheels, and the Up-Country option with the 1-1/2Ē lift.
Anyway, after having the same problem occur with three different sets of tires, two of which were new, Iím reasonably certain itís not the tires causing the vibration. Does anybody have any idea what the cause could be?
Thanks for your help.
Jim
