1988 Jeep Cherokee Fog Lamp Installation
doubledouble
PostPosted: Mon Jul 24, 2006 9:16 pm    Post subject: 1988 Jeep Cherokee Fog Lamp Installation Reply with quote
I'm looking into installing a set of fog lamps on my Cherokee and I need some advice.
The vehicle did not come equipped with fog lamps from the factory, but I have a feeling that all wiring is present. I purchased a factory fog lamp switch and bezel and I want to use all existing wiring. I don't want anything fancy, just the simple factory look.
I noticed on the front bumper that there are a total of four plastic caps. I'm guessing that these caps are for mounting the fog lamps. Do the fog lamps use two holes per lamp for mounting the lamp to the bumper, or is one hole for mounting and the other for running the wires?
If both holes are necessary for mounting, then the wiring must go through the front grille. I'm just not sure, that's why I'm here.
Does anybody know where I can get a pair of OEM fog lamps for my Cherokee? I don't want any type of modification, just a simple bolt on upgrade.
Also,a relay will be needed. Will this relay be located in the convenience center at the RF engine compartment?
If anybody has experience with this upgrade or if anybody has a Cherokee (of the same year or close to it) with factory installed fog lamps, all help would be greatly appreciated.
