which end to lock????
mattyj074
PostPosted: Wed Jul 26, 2006 10:56 pm    Post subject: which end to lock???? Reply with quote
i am going to install a power trax no slip locker to my 98 XJ. But have had mixed reports & opinions from different people on which end to fit first. I would like to do front & rear eventually but for now its just going to be one...... So would it be more beneficial to have it in the front or rear for wheeling??
97XJ Jeeper
PostPosted: Thu Jul 27, 2006 2:52 pm    Post subject: Reply with quote
i would do the rear first, that will make a big difference in off road
JUST PUT IT IN 4X4 AND GO FOR IT!!!
Magnaflow high flow cat
FLOWMASTER SUPER 40
2 1/2" pipe cat back
Videos my XJ
http://youtube.com/profile?user=JeepXJJeeper
PostPosted: Thu Jul 27, 2006 8:16 pm    Post subject: Reply with quote
The general rule of thumb is to lock the rear before the front. I went the other way around...but I had mechanical reasons for that. Wink
Ptown_bogger
Guest
PostPosted: Sat Jul 29, 2006 7:31 pm    Post subject: Reply with quote
and what exactly were your "mechanical reasons" for locking the front first? just curious.
if your putting in an automatic locker on a daily driver, its a good idea to put it in the rear and have a selectable in the front (Ox, or ARB). you dont really wanna deal with steering issues upfront. and it would be nice to be able to lock it only when you need it. A locker up front really only ever wants to drive straight, you turn the wheels and it acts as if you did nothing most of the time. In short you'll be much happier with an automatic in the rear and selectability up front.
PostPosted: Sat Jul 29, 2006 8:43 pm    Post subject: Reply with quote
Going with the powertrax in the first place was and still is a temporary solution until I do full regear.
The reason I choose the front is that I didn't (and still don't) trust the bearings in the rear axle...both at the pinion and in the carrier itself. Locking puts a lot of extra stresses on them. When I put the axle in two and a half years ago, it had an unknown amount of miles on it. It was the right ratio to match the front and I choose to do a rear disc conversion and put in alloy shafts as prep for regear...so I didn't touch the internals. When I put the powertrax in last year, I knew the entire history and condition of the front axle so I choose to go that route.
When I put the new lift under it this past winter, I ran out of money before I regeared. So I'm putting together the scratch now to rebuild and regear both axles this winter with 4.56's and Ox's. Then the Powertrax will go in the TJ, which already has a Lockright in the rear.
There is a method to my madness. Wink
Ptown_bogger
Guest
PostPosted: Sun Jul 30, 2006 11:08 pm    Post subject: Reply with quote
what axle do you have in the rear? Is it the 8.25? I have the 8.25 29 spline for my rear axle and i was under the impression that these were good axles. Are they're things i need to be aware of? Do the pinion bearings wear out pretty easy?
PostPosted: Mon Jul 31, 2006 1:13 pm    Post subject: Reply with quote
I replaced my 8.25 axle with a D44 from an 87.
JtotheEEPxj
PostPosted: Mon Aug 14, 2006 9:12 am    Post subject: Reply with quote
STAY AWAY from the powertax No Slip, bad idea. they break very easily with any type of heavy offroad use. When i returned mn, they had heard of several other people having thesame problem.
"If it ain't dented, ya ain't wheelin' hard enough"
-1993 XJ, 4.0, 5 spd, 4.5" lift, 32's, Warn bumper, JKS link kit, skid plates, D30 & 8.25 w/ 4:56's & Detroit locker
-1965 Ranchero, new paint & interior, 302, C4, torque thrust II whls
