1999 Cherokee oil pressure
99cherokee
PostPosted: Wed Jul 26, 2006 5:21 am    Post subject: 1999 Cherokee oil pressure Reply with quote
The oil pressure is reading crazy, When I just turn the key before you start it and all the guage lights come on it goes to 40 when it is supposed to be at zero.
And then when you start it the pressure sensor goes straight to 80 and stays there.
Anyone have this same problem and got it fixed is it the guage or the oil pressure switch?
Any help would be awesome..
thanks
Widdy
PostPosted: Thu Jul 27, 2006 3:16 am    Post subject: Reply with quote
Yup!! I did on my 93. All i did was check my pressure sensor connector. It must not have had a good connection. After i took it off and then put it back on it started working fine.
99cherokee
PostPosted: Thu Jul 27, 2006 7:20 pm    Post subject: Reply with quote
I changed the sensor today and it appears to have fixed it lets hope
thanks widdy.
