5-Speed Transmission Adjustment
RPCherokee
PostPosted: Wed Aug 02, 2006 9:09 am    Post subject: 5-Speed Transmission Adjustment Reply with quote
5-Speed Transmission Adjustment:
I took my 2001 Jeep Cherokee in to get the odometer fixed. Turns out the odometer was fine but the transmission needed to be fixed. When I drive over 60 mph the odometer goes up to 100 mph and does not give an accurate reading. Also I noticed after this was worked on but not completely fixed that the milage jumped about 20,000 miles up. Not exactly the best mechanic.
My question is what exactly is going on here and is this something I can fix myself? What areas need to be adjusted and does this take special tools?
I would probably need some pics to help explain this since I am an amatuer and have little experience with cars but I can fix just about anything.
disorder
PostPosted: Fri Aug 04, 2006 6:09 pm    Post subject: Reply with quote
not too sure about these tranny's but it could be the small speedo gear, the teeth on it could be busted and/or worn away. it might be the problem, its the only thing i can think of.
