5th gear
TheNewGuy
PostPosted: Mon Aug 07, 2006 1:26 pm    Post subject: 5th gear Reply with quote
I just bought a 91 yj, it's in good condition, but when I switch into fifth gear it falls back into neutral, unless I gas it while shifting, and the second I let up on the gas it falls back into neutral
Anyone have an idea of what the problem is, and how it can be remedied
tonloco
PostPosted: Tue Aug 08, 2006 5:08 am    Post subject: Reply with quote
sounds like a detent ball is missing Or does it actually fall back into nuetral or does it stay in the 5th gear poasition an just reacts like nuetral. if it is the latter the retainer clip for 5 has either come loose or broke unfortunatly the AX-5 are notoriuos for it. on either situation you will have to crack open the tranny
good luck
TheNewGuy
PostPosted: Tue Aug 08, 2006 2:15 pm    Post subject: Reply with quote
it actually falls back into neutral
