2000 Cherokee 4WD Panel Problems
jeepnNY
PostPosted: Thu Aug 10, 2006 4:19 am    Post subject: 2000 Cherokee 4WD Panel Problems Reply with quote
When I put the transfer into 4WD H and L the panel identifier doesn't come on. There are no problems with the 4WD, works like a CHAMP!!!! Should I just let it go or could this be an identifier of problems to come? Also, any good ideas on mods; looking at a 3.5 lift with 31's. Let me know what you guys (and gals) have done and what you'd recommend for a novice. Thanks!!!
JeepinNH
PostPosted: Thu Aug 10, 2006 7:12 am    Post subject: no light Reply with quote
There's a switch underneath that can stick, that is most likely your light issue not an impending 4x4 failure. There's lots of info in this site about mods. Just takes some looking around. The "stickys" section is a good place to start.
Mike
Present: 99 Cherokee
