Diagnostic Trouble code history record available?
Post new topic   This topic is locked: you cannot edit posts or make replies.     Forum Index -> Cherokee Forum
cmyachtie
PostPosted: Fri Aug 11, 2006 4:39 am    Post subject: Diagnostic Trouble code history record available? Reply with quote
I know it's probably wishful thinking but I was wondering if the 2001 TJ stores its trouble code history.
Anyone have any idea?
I would like to know what the code was when i took it to the dealer, the check engine light was on and I took it in instead of first checking what the code# was, they replaced the LDP, solenoid and $500 later i am not too happy especially since I keep reading that it was not likely the root cause.
Thanks
PostPosted: Fri Aug 11, 2006 9:57 am    Post subject: Reply with quote
http://www.jeephorizons.com/phpbb/viewtopic.php?t=9060
Post new topic   This topic is locked: you cannot edit posts or make replies.     Forum Index -> Cherokee Forum All times are GMT - 8 Hours
