Will Pro-Comp 2.5" lift leafs drop any after install???
vrogers64
PostPosted: Fri Aug 18, 2006 3:28 pm    Post subject: Will Pro-Comp 2.5" lift leafs drop any after install??? Reply with quote
I installed a set of Pro-Comp 2.5" lift leaf springs on a '97 Cherokee. I ended up with closer to 3.5" of lift. I need to get shocks and match the front to the rear, but I have heard of some leaf springs dropping an inch or more after a few weeks. My original plan was these leaf springs in back with spring spacers on the front coils, but now it's looking like 3" springs - maybe even with 3/4" spring spacers. The shocks I had planned are 22.5" extended, and I'm currently measuring 21.5" sitting with a close to empty tank. I don't think 1" drop is enough on the shock - but 2" is probably okay.
Any help geatly appreciated!!!
