creaking sound from underneath
xjcherokee
PostPosted: Fri Aug 18, 2006 5:23 pm    Post subject: creaking sound from underneath Reply with quote
gotta problem. when i drive over speed bumps, or anything that cause weight to be transfered (turning, goin up and down slanted ground) there is a loud creaking sound (the kind of sound like on a wood floor) any help would be appreciated! anyone think they know what it is?
JeepinNH
PostPosted: Fri Aug 18, 2006 5:30 pm    Post subject: Reply with quote
front? back? side? I have a door that creaks and in the front the sway bar rubs on the frame on certain angles which makes a scraping type noise. I think I need new bushings.
Mike
Present: 99 Cherokee
xjcherokee
PostPosted: Fri Aug 18, 2006 7:01 pm    Post subject: Reply with quote
sounds like its comin from the right front tire, and also when i go over speed bumps its only when the front tires go over it, not the rear and it sounds liek its comin from the passenger side
Joh's jeep
PostPosted: Fri Aug 18, 2006 8:28 pm    Post subject: Creaking noise Reply with quote
I had a similar thing with my 97 Cherokee Country, and I found that the plastic coating of the domelight switch (driver's side door opening) was missing. The metal of the switch "scratched" on the door with every weight shifting resulting in body torsion. I put some lube on the switch and the sound was gone....
Your problem may be more serious than that, but the noise produced by this switch was pretty amazing considered the simple cause.... ....so you may check into this anyways.
Best,
Johannes
