preferred axles
langston
PostPosted: Sun Aug 20, 2006 11:43 am    Post subject: preferred axles Reply with quote
i have a 2000 sport with 6" body lift and 35" goodyear MTRs. the axles are stock, and i want to swith them to get more power. what do you think i should switch them to to get good performace for my money (dana 44 maybe...?)
PostPosted: Sun Aug 20, 2006 12:12 pm    Post subject: Reply with quote
6" body lift??? Where did you find that?
Switching axles doesn't get you more power. Regearing axles to a lower ratio (numberically higher) gets you better performance with those larger tires. What transmission...manual or auto? What axles do you have now? You may already have a D44 in the back. If so, look into regearing what you've got. Depending on your transmission, I'd recommend 4.56 or 4.88 for the manual tranny and 4.10 for the auto. Any lower with the auto and you really will have the RPMs cranked up on the highway.
langston
PostPosted: Sun Aug 20, 2006 5:07 pm    Post subject: Reply with quote
ha, i meant 4" suspension, and 2" body so 6 total. ill have to look 2morrow, but im pretty sure its dana 35 in the rear. manual tranny too
