problem with driverside tail light
wranglerRyan
PostPosted: Tue Aug 29, 2006 9:05 am    Post subject: problem with driverside tail light Reply with quote
my drivers side tail light sometime will not work. and it will cause the front turn signals to blinck out of controll. but when i tap the light it will work but going down the and i hit a pot hole it will stop working. I dont know if i just need to get a new light so what ever but if any one has any suggestions, please help.
KnightFire
PostPosted: Tue Aug 29, 2006 9:27 am    Post subject: Reply with quote
Sounds like a loose ground, check your connections.
2002 TJ Wrangler X
Patriot Blue 4.0L
Check Website for Mods/Photos
Amsoil Dealer
wranglerRyan
PostPosted: Tue Aug 29, 2006 9:33 am    Post subject: Reply with quote
no i check all of that the wiring hareness was fine and in good shap
kizer
The Link Meister
The Link Meister
PostPosted: Tue Aug 29, 2006 10:24 pm    Post subject: Reply with quote
Now when you say blink out of control. Do you mean like a really fast blink or do they blink left to right?
Fast blink means your Jeep senses a burned out bulb, which in this case could be a ground or a loose bulb in your rear tail light housing. Pull the bulbs and make sure they are clean and seated tightly.
A bad ground is a possibility, but if you haven't changed anything then its less likely, but not impossible.
Links4Jeeps.com
1600+ Write-ups, and more
My Writeups | My Heap
PostPosted: Wed Aug 30, 2006 5:53 am    Post subject: Reply with quote
Replace the bulbs.
Either that or a bad ground.
wranglerRyan
PostPosted: Wed Aug 30, 2006 7:23 am    Post subject: Reply with quote
i fix the bottom of the bulb had a crack in it and was giving it a bad connection. Thanks though
meash20
PostPosted: Fri Oct 20, 2006 11:42 am    Post subject: Reply with quote
I have a 97 TJ and I have a similar problem, except I have changed the light bulb and am still having problems. I did note that the light was not bad, the one I took out.
-matt-
meash20
PostPosted: Mon Oct 23, 2006 6:04 am    Post subject: Reply with quote
Additional information about this, The tailight as a whole doesn't work. The left turn signal flashes quickly when on, since the back doesn't work.
What should I check for this?
Any help is much appreciated, this tends to be a safety issue since people behind me can't tell when I want to make a left turn.
-matt-
PostPosted: Mon Oct 23, 2006 1:30 pm    Post subject: Reply with quote
ehirner wrote:
Replace the bulbs.
meash20
PostPosted: Mon Oct 23, 2006 5:56 pm    Post subject: Reply with quote
I would tend to agree, however the Tail light is working, it is only the Turn Signal and Brake Light is not.
Any additional suggestions?
-matt-
never lost
PostPosted: Sun Nov 12, 2006 11:41 am    Post subject: Reply with quote
Look at the socket. Is the bottom corroded? Is the socket bent or need to bent in to hold the bulb properly. I had the same problem. The bulb was new and the ground was good. The socket was bent. It took 2 seconds to fix.
meash20
PostPosted: Mon Nov 13, 2006 8:45 am    Post subject: Reply with quote
I will double check that tonight... I thought that I had, however with my busy schedule I can't recall... Thanks AGAIN!
-matt-
