OBD CODES 1997 GRAND
1997GRAND
PostPosted: Wed Aug 30, 2006 7:28 am    Post subject: OBD CODES 1997 GRAND Reply with quote
CAN ANYONE HELP ME MY JEEP IS AT THE SHOP TRYING TO GET IT INSPECTED BUT THEY TELL ME THEY CAN'T GET THE CHECK ENGINE LIGHT OUT . COMING UP WITH A CODE 300,301,303 MISFIRE DETECTED
SHE RUNS GREAT HIGH RPM AT IDLE IT'S ALITTLE ROUGH. THEY SAY THAT CYC NUMBER1 IS AT 100LBS OF COMPRESSION ALL THE REST ARE 150 OR BETTER. thEY CHANGED THE CRANK SENSOR STILL NOTHIG .
NOW THEY TELL ME THE HEAD HAS TO COME OFF TO CHECK THE VALVES
THE JEEP HAS 107000. IS THERE ANY ELSE IT GOOD BE BEFORE GOING THIS ROUT PLEASE HELP THANK YOU.
monkeyman3875
PostPosted: Wed Aug 30, 2006 12:08 pm    Post subject: Reply with quote
Did they tell you why they wanted to remove the head? That's your first problem. Don't let them touch the head until they know why it's losing compression. Did the engine overheat ever? Could be warped.
1. If the jeep ever seriously overheated, the head could be warped.
2. probably a leak. -- spark plugs, valves, manifold ports maybe?
(Note: definately find out why, removing the head is about 8 hours labor alone)
I had to take the head off because the engine overheated, warped the head, and I was losing compression in 3 of the 6 cylindars (stock 4.0L).
-1997 Stock XJ
-4.0 L
-4-speed automatic
1997GRAND
PostPosted: Thu Aug 31, 2006 2:48 am    Post subject: obd code Reply with quote
NO the jeep has never over heated , They said they shot some prussure in the # 1 cyc and the pressure shot out of the trotle body so the feel the vaule is stuck open . It drive me crazy because the truck runs great .
monkeyman3875
PostPosted: Thu Aug 31, 2006 3:29 pm    Post subject: Reply with quote
it happens, i just found out one of my injectors is leaking. after 15+ min. after shut down the fuel leaks out.
-1997 Stock XJ
-4.0 L
-4-speed automatic
monkeyman3875
PostPosted: Thu Aug 31, 2006 3:30 pm    Post subject: Reply with quote
also, did they already do the work? cause it not (and you're mechanically inclined), get the jeep back, pull the head yourself and just take it to a machine shop to get it fixed. Saves you 8 hrs labor from a mechanic.
P.S. don't use caps. it's considered yelling, and even if you're pissed, don't take it out on us.
-1997 Stock XJ
-4.0 L
-4-speed automatic
