AMSOIL lubes
EJ
PostPosted: Mon Sep 04, 2006 3:34 pm    Post subject: AMSOIL lubes Reply with quote
I'm looking to put Amsoil products in my 2004 Jeep Grand Cherokee limited SE, V8 but not sure which or how much to purchase. I want the motor, transmission, gear boxes and grease (u-Joints, ball joints and wheel bearings). Any suggestions on which and how much I need?
Thanks
EJ
PostPosted: Mon Sep 04, 2006 5:19 pm    Post subject: Reply with quote
Contact Dirk at 4x4oil.com he is a fellow Grand owner and a dealer of Amsoil.. Thats all I run in my Jeep and in my Montero ..
He can hook you up with quantity and types of whatever you need...
Carl
EJ
PostPosted: Mon Sep 04, 2006 7:24 pm    Post subject: Reply with quote
thanks Carl
jakster
PostPosted: Sun Sep 10, 2006 6:49 pm    Post subject: Reply with quote
I am also an AMSOIL dealer and I run it in everything I own. AMSOIL has several blends of lubricants that meet or are better than what the manufacturer require. First how do you use the Jeep is it in break in or is it well used. Cold or hot climate Automatic or manual? Flush your engine with AMSOIL engine flush for one half hour at idle in the drive way then dump the old sludge out. Next you will want to change the filter the AMSOIL standard filter is great better than any thing you can buy off the shelf because it has a bypass valve that actuall works and does not stick open after 1500 miles and stays open. They also make a Donaldson Filter that is even better if they have one for the Jeep In am a new Jeep owner and don't know yet ,sorry.
As far as oil the offroad stuff would be the high performance racing oil but the 7500 is also outstanding oil. the grease and gear oil and transmission fluid are the best your money can buy. Jim at krugerrand@netscape.com send me an email with your address and I will get a catalog in the mail and explain how you can buy the oil at dealer cost.
