Later model radiator for XJ
Kiwi
PostPosted: Thu Sep 07, 2006 6:36 pm    Post subject: Later model radiator for XJ Reply with quote
HiYas
Searched the forum for this, but came up empty.
I read you can replace a standard XJ radiator ( mine is a auto 96 sport ) with a later model one.
I have access to later model ones, but do not know which is the best, or straight swap out for my jeep.
Any advice will be appreciated
Cheers
PS: mine is now leaking R/H side top, where the rubber seal is between the core and plastic part...dammit.
88WOWJ
PostPosted: Fri Sep 08, 2006 6:45 pm    Post subject: Later Model radiator for XJ Reply with quote
Most radiators are plastic tanks with either copper core or aluminum.
The old XJs did come with all metal rads. Yes their several companies making all metal rads. You just have to search. Could get a little pricey.
a new 2 core rad form Advance Auto about $135.00. Plastic tanks
1991 Cherokee Limited
Kiwi
PostPosted: Fri Sep 08, 2006 8:25 pm    Post subject: Reply with quote
Cheers mate.
Seen the new ones. I should of elaberated a bit more Smile A customer of mine is a wrecker, and has several Jeeps in stock. A grand and a Cherokee.
Was after more or less will a grand fit a sport like mine. Particually years and if they are a good option vs going brand new. Apart from the obvious new, I would get the second hand one serviced.
