1995 Grand Cherokee Overdrive
mudans
PostPosted: Mon Sep 11, 2006 9:03 am    Post subject: 1995 Grand Cherokee Overdrive Reply with quote
My jeep has a problem with its overdrive. Occasionally while driving, my overdrive will turn on and off on its own. The control on the dash is not stuck or jammed. Has anyone encountered this problem or have any advice?
Thank you in advance
RussellRowell
PostPosted: Mon Sep 11, 2006 6:52 pm    Post subject: Reply with quote
can u turn your OD switch on and off and visually see the light come on and off. My jeep has been doing the same and my switch works when it wants to. it could be the overdrive solienoid not venting or is shorted or going bad. been waiting on some extra cash to check everything. something i been wanting to do but cant find the time. take it to auto zone and have them scan your jeep with an OBDII. i heard they'll do it for free. if you go there, let us know what you find out.
1994 w327k
PostPosted: Mon Sep 11, 2006 8:17 pm    Post subject: Reply with quote
I would think overdrive solinoid also.
PostPosted: Tue Sep 12, 2006 10:47 am    Post subject: Reply with quote
my torque converter was goin bad when it did that, lost lockup torque converter, the trans started to get hot and knocked it out of overdrive
redzjon31's
PostPosted: Wed Sep 13, 2006 12:25 pm    Post subject: Reply with quote
1995 ZJ you cant use the OBD II scanner on. OBD II is for 96 and newer
PostPosted: Wed Sep 13, 2006 12:44 pm    Post subject: Reply with quote
he didnt consult the service manual for that rofl rofl rofl rofl rofl
haha you the man, i didnt even catch that
RussellRowell
PostPosted: Thu Sep 14, 2006 6:19 pm    Post subject: Reply with quote
My mistake! I should of said DRB/DRB 1 scan tool. Pre 96 can be scanned. The data link connector is near the a/c lines close to the firewall. Little square black box according to THE BOOK. bowdown
Remember, a DTC (dianostic trouble code) may indicate the result of a failure, but never identify the failed component directly.
