CV Boot on 1999 Grand Cherokee
steveandtracy7
PostPosted: Thu Sep 21, 2006 2:17 pm    Post subject: CV Boot on 1999 Grand Cherokee Reply with quote
I have a torn front outer cv boot on my 1999 Grand Cherokee. I was wondering if someone could tell me how difficult it is to change this. I have average knowledge of repair work, but have never changed a cv boot or axle. If someone could help me and give me advice on how to do this I would greatly appreciate it. Thanks
PostPosted: Thu Sep 21, 2006 4:21 pm    Post subject: Reply with quote
First things first.. chock wheels... Jack it up .. Take off tire..
Remove brakes pull off rotor cap..
Take off the 3 13mm 12point screws on the back of the unit bearing...
Pop off unit bearing and the axle should Slide out with it..... Change U joint ...Reinstall...
You will probobly have trouble getting the unit bearing off.. Tap it lightly with a rubber mallet.. back and forth..
If that doesnt work move up to a brass hammer ... If that doesnt work try a 20# sledge... rofl
ITs not that hard.. You can do it in about 3 hours first time and 45 min. everytime after that... Mr. Green
PostPosted: Thu Sep 21, 2006 7:41 pm    Post subject: Reply with quote
yea, hub assemblies are about the same way, after the first time, you can do it much faster the second, im down to 10 mins now, 4 in 2 weeks makes you good hahah
