rear turn signal light does not work
never lost
PostPosted: Sun Sep 17, 2006 7:37 pm    Post subject: rear turn signal light does not work Reply with quote
I have a 97 JT that the driver side rear turn signal does not work. The driver side glows brighter then the passenger. I checked the ground, thatís good. I switch the bulbs from the passenger to the driver side, it did the same thing. I sacrificed a chicken, still doesn't work. The last thing is to replace the Multi-Function switch aka turn signal unit. Does anyone have any ideals? The chicken was tasty too. Wink
vtcruiser
PostPosted: Thu Sep 21, 2006 3:57 am    Post subject: Reply with quote
I just had the same problem with my jeep. It turned out it was the turn signal swith. No problems after that was replaced. Total cost was about $120. I didn't have time to do it myself, so I let a mechanic do it.
