Smoking and Pulling to the right while braking??
PostPosted: Sat Oct 07, 2006 3:24 pm    Post subject: Reply with quote
dubbleJ's wrote:
Happen to know a torque rating?
31 Nm (23 ft. lbs.)
Just be sure that you're crushing the washers - they're called seal washers for a reason.
dubbleJ's
PostPosted: Sat Oct 07, 2006 5:32 pm    Post subject: Reply with quote
ehirner wrote:
dubbleJ's wrote:
Alright well I went and tightened them really f'in tight, to the point the bolt head was cutting into the washer. We'll see if it leaks at all by tomorrow, if so I guess I will have to get thinner washers.
It's not the width of the washer.
What is it then??
You are right that just a reflection, there is only two wasehrs in total.
Also I know that they are called crush washers for the reason that they crush and make a seal. As i stated already, I tightened them past the point that the bolt head is cutting into the washer, you cannot possibly crush them more. Thanks for the torque rating I will go make sure it is at at least 23ft/lbs.
