Author |
Message |
soulknight Member
Posted: Fri Apr 20, 2007 9:31 pm Post subject: 242/6 speed tranny |
The 242 and 231 share the same bolt pattern. The input shaft may be different than other trannys used but I doubt it. If it is drivetrain.com will customize it for you. |
Back to top |
campingmikey Member
Posted: Sat Apr 21, 2007 5:19 am Post subject: |
Awesome. I don't know if that's a good thing or not... Now I have to work more to get some money. Thanks for the help! |
Back to top |
Brad The Best Member
Posted: Sun Apr 22, 2007 9:12 pm Post subject: |
the only years that i believe the input shaft size was different was back between uhm 91 and earlier , i remember because when i put my 242 (got rid of the 231 , well its sitting around with a transmission hooked to it because its brand new )in i had to swap the tranny with it . so you should be okay with the same years . |
Back to top |
