Rubicon 44
nixt
PostPosted: Wed Oct 11, 2006 11:54 am    Post subject: Rubicon 44 Reply with quote
Does anyone know where I can find all of the specifications on the rear Dana 44 that was used in the Wrangler Rubicon? I'm looking for the ABS specs, wheel mounting surface distances, shock and spring mount measurements, brake setup, limited slip/locker info, and all other necessary measurements to try to swap in the iron 44 to replace my GC's rear axle. I've read that the 44 assembly can be purchased at the dealer for around $800.
JKS disconnects & Garmin GPS
Heavy duty OME Suspension kit
Life has No Value,
But Death Has Its Price.
nixt
PostPosted: Wed Oct 11, 2006 1:08 pm    Post subject: Reply with quote
I've been told that the Wrangler doesn't have ABS. If this is the case then I'm wasting my time with the Rubicon 44. So just disregard the post- I'll have to look elsewhere.
Life has No Value,
WhatWasIThinkin
PostPosted: Wed Oct 11, 2006 1:59 pm    Post subject: Reply with quote
Well just to confirm it, there is no ABS with the D44 axles.
Real Jeeps dont wear Bra's
