YJ Mechanical Fan is to long on the XJ Motor
PaintballYJ
PostPosted: Wed Oct 11, 2006 6:20 pm    Post subject: YJ Mechanical Fan is to long on the XJ Motor Reply with quote
I'm putting a 92XJ 4.0 motor in my 4.2L 88YJ. I have it installed and have started the wiring and I went to put the serpentine belt on and the YJ water pump that I installed is sticking out way to far? The belt does not line up with the power steering pump pulley or the crank pulley? I can get it to go on but it is noticeably offset. Has anyone else had this problem? Did I forget to switch out a Pulley?
Any help would be appreciated.
Thanks,
PaintballYJ
PaintballYJ
PostPosted: Fri Oct 20, 2006 8:09 pm    Post subject: Reply with quote
I Fixed it. The problem was I was sold the wrong water pump pulley.
Thanks for all your help,
PaintballYJ
Troll
PostPosted: Thu Apr 19, 2007 10:25 pm    Post subject: Reply with quote
I am having the same issue, but I put a 1989 4.0 XJ engine in my 89 YJ 4.2L. Any help would be GREATLY appreciated.
Thanks.
