engine stalling and or diying
jeeper
PostPosted: Sat Oct 14, 2006 3:17 pm    Post subject: engine stalling and or diying Reply with quote
hello guy i need help pls. my zj have been stalling,and or diyng on me even after i have replaced the cps. aside from that camshaft,idle,throttle sensors were also replaced. problem occurs when slowing down to a stop and sometimes at idle after starting the engine. been reading the post looks the cps is the problem,i do not know if iinstalled the cps correctly.please advise. thanks
RyanLodge
PostPosted: Sun Oct 15, 2006 6:02 pm    Post subject: Reply with quote
Jeeper!! I'm a newb and had the exact same problem. My crank sensor failed one day ( luckily in the drive way) and It needed to be replaced. After that, the jeep would stall after coming of a highway, or coming to a stop. So far I replaced the sparkplug wires, coil wires, distributor cap and rotor, and it hasn't stalled since. Check your wires at the cap, 2 of mine we strangishly coroded inside, the rest were cleam. Check it out, if it looks the same, give it a shot and tell me if this solves your problem as I almost bought another crank sensor to install.
PostPosted: Sun Oct 15, 2006 7:07 pm    Post subject: Reply with quote
Try to take the throttle body off and clean the Idle air control area (change that if you havent already) Use throttle body cleaner not Carb cleaner.
Good luck
martini_thief
PostPosted: Mon Oct 16, 2006 2:13 pm    Post subject: Reply with quote
I agree with swamp boy...
My ZJ did this for a month till I bought and used $3 worth of throttle body spray, I just follwed the directions on the can, and its never happened since.
