bad waterpump??
topsideroyal
PostPosted: Sun Oct 15, 2006 12:54 pm    Post subject: bad waterpump?? Reply with quote
i keep losing a lot of coolant out of my 2000 GC. i think it might be a possible bad waterpump. anybody else havin the same problem
PostPosted: Sun Oct 15, 2006 2:42 pm    Post subject: Reply with quote
Where's the coolant coming from? Which engine and does it look like it's dripping down onto the crankshaft pulley?
PostPosted: Sun Oct 15, 2006 7:32 pm    Post subject: Reply with quote
What he said..
Bad waterpump is normally very easy to diagnose. Your bearing gets hot and melts the rubber seal and water drips out the weap hole ..
If your water pump is leaking water . You need to change it..
