120k service
erther
PostPosted: Mon Jul 18, 2005 11:53 am    Post subject: 120k service Reply with quote
I just bought a 97 tj w/ 113k miles on it, and since I really don't know how the previous owner maintained it, I thought I'd do a basic tune-up.
Other than plugs, wires, and t-case fluid, what should I replace/fill/check?
stock '97 tj sport
PostPosted: Mon Jul 18, 2005 12:22 pm    Post subject: Reply with quote
If you don't know how it's been maintained, in addition to the things you've mentioned, I'd change the transmission fluid, air filter, diff fluid, radiator, rotate the tires, check the bearings and grease everything.
