Interior door handle
allstar31
PostPosted: Tue Oct 17, 2006 1:20 pm    Post subject: Interior door handle Reply with quote
So my window regulator broken so I thought why don't I replace it.... to make a long story short I broke one of the clampy things that hold the rod to unlock the door. I bought the replacement part and when I took the door off again it looks almost like it's riveted on. Any suggestions on what I need to do to get the new handle back on? BTW I have a 2000 Jeep Sport Cherokee.
allstar31
PostPosted: Tue Oct 17, 2006 2:49 pm    Post subject: locking rod in door Reply with quote
I got that fixed now the problem is that I bent the rod that unlocks the door I have tried to re-bend it but I can't get it working does anybody know how they work or what I need to do to get it to work?
TheBrat97
PostPosted: Tue Oct 17, 2006 4:11 pm    Post subject: Reply with quote
i had the same problem when i put my speakers in...you have to use your strength and bend the rod straighter
allstar31
PostPosted: Tue Oct 17, 2006 7:02 pm    Post subject: Reply with quote
I think the problem is that it is too straight the rods should line up when the door is in the locked position. I can't get them to line up and I have bent the hell out of it
dancerman
PostPosted: Fri Oct 20, 2006 11:00 am    Post subject: Reply with quote
You could remove one from opposite door and compare. Of course it will be an opposite geometry but may help you reshape the one you goofed up.
