Grand cherokee has been sitting for 2 years.
fingarr
PostPosted: Sat Oct 21, 2006 1:43 pm    Post subject: Grand cherokee has been sitting for 2 years. Reply with quote
I just picked up a 93 ZJ 5.3l. It has been sitting in the hot sun for 2 years and i want to clean the vital parts and change fluids. What should I check or refill. Im going to change the oil and filter, plugs. It started right up with a new battery and sounded strong. I just dont want to miss something and ruin the engine or anything else. Any suggestions will help. Im going to go through the manual tonight.
PostPosted: Sat Oct 21, 2006 8:48 pm    Post subject: Reply with quote
If it were me, I'd likely change every fluid and filter:
Oil
coolant
transmission
t-case
differentials
brake fluid
power steering fluid
And I'd take a very close look at any rubber hose and/or belt. Check your brake lines closely to make sure they haven't started to crack. Pump the brakes a few times to get the pressure up on them. Oh yeah, was the gas tank drained before it was parked?
PostPosted: Sun Oct 22, 2006 4:20 pm    Post subject: Reply with quote
What he said.
And pour a tiny bit of oil down each spark plug and turn it over with the plugs out before you try to start it.. IN case the oil ring has gotten dry
