Power loss during acceleration
Bson
PostPosted: Sun Oct 22, 2006 1:24 am    Post subject: Power loss during acceleration Reply with quote
Hi! Recently bought a 97 Cherokee, it's been working fine since we bought it and other than a main seal change at the "oil service" last week there has been no issues...
While driving today (two weeks after the service and the seal change) I noticed that during acceleration from very low speads the engine power drops, like if I was taking the foot off the gas pedal...
It happened a few times today and the engine was warm every time. It never hapens above 20 km/h, only when I accelerate from low speeds.
I've searched around without finding many clues... I'm guessing fuel pump or fuel hose leak, but can not see anything strange under the hood.
Can some one help out?
/Bson
PostPosted: Sun Oct 22, 2006 11:11 am    Post subject: Reply with quote
Has it recently been tuned up? Have you checked for engine codes? If all of that's fine, my guess would be your crank position sensor.
adamzski
PostPosted: Mon Oct 29, 2007 7:55 pm    Post subject: Re: power loss during acceleration Reply with quote
I had the same problem, my cherokee XJ has a manual transmission, and at first i thought the clutch was slipping, so dont rule that out if it applies to you. after ruling that out, i replaces the tps, map, and iac. the sensor that made the most difference for me was the tps, if you do alot of highway driving, our tps can get worn at one spot, and when you hit that during acceleration, it will send an incorrect reading to your computer causing it to buck and loose some power at that point, so i would try that.
